Yasmar
I've owned the bike since the beginning of summer. I drive it everyday back and forth to work (rain or shine).
One of the complaints I've had is with how the bike shifts. Sometimes it's a smooth ratchet like shift and sometimes it's a vague double click feeling (and not just between 1 and 2 obviously as there should be)
I'm sure using synth oil might smooth things out a bit, but I prefer to just use regular oil and change it very frequently.
Anyways, to get to the point, the method I use for smooth consistent shifting (just upshifts, downshifts requires a different method) is to slightly (and I mean slightly, as in 1 pound of force) preload the shifter (ie pulling it up with very little force) and making sure your revs are above 5500ish. It seems that the bike shifts poorly below this RPM <but not consistently poor which is the strange part> (note: I use my clutch too
Before this I was typically shifting the bike around 4800 or so but noticed that with higher revs came smoother performance.
Hope this is helpful to someone. Let me know if you've experienced the same thing with the transmission in this bike, or maybe there's a better method for smooth consistent shifts.
Yasmar
ps. I blip the throttle when down shifting the bike. Smooths everything out nicely. Plus it's good practice for keeping consistent brake pressure and changing the engine speed all with the same hand! <very difficult actually> <you can use the back brake to practice the concept of blipping the throttle at first then switch to your right hand>
<warning you'll be bobbing up and down a bit till you get good at it
Yasmar
