I got your PM and responded.need some help installing my integrated light...
the light comes with blue and yellow wires'--- and the stock wires are both brown... which one goes whre?? also the black wires--do i just bolt those underneath a nut and tightened it up?
please help.. i already blew a fuse the first time.
eddie
sweet thanks man. yea i figured what was the problem. it looks like it needs a bigger fuse than a 15. i put a 20 on the fuse box turn signals and it seems to be working.I got your PM and responded.
Yes, LED's draw less power than halogen bulbs so the bike thinks there's an issue. You can get a new relay that will fix that. There's a thread somewhere with the relay, do a search and you should be able to find something.also-- is the fast blinking normal??
Yeah, the reason is that the bike is looking for a specific load on the circuit. Because LED's draw a lot less power, the bike thinks that you have a blown bulb, so it flashes fast like that. I like the fast flash, but I have thought about replacing the flasher relay so that it would be fixed.sweet thanks man. yea i figured what was the problem. it looks like it needs a bigger fuse than a 15. i put a 20 on the fuse box turn signals and it seems to be working.
Eddie
Eddie
Eddie and Chris: Eddie: This is what you are looking for. Chris, just letting you know so you know where to find it now!Yes, LED's draw less power than halogen bulbs so the bike thinks there's an issue. You can get a new relay that will fix that. There's a thread somewhere with the relay, do a search and you should be able to find something.
