Mirror base plates
As someone stated previously in a thread, the stock mirror mounts for yr 07-08 zx6r fit the stock mounts for the fz6r. so i purchased a set of 07-08 zx6r mirror block offs from ebay and they fit perfectly.
OP the link doesn't work.
And if the ZX mirrors do line up perfectly (heard it does from a couple of members on here) then I would do as mentioned above and look into that bike's mirror block-off plates.
The R1, R6, R6s Mirrors will not bolt on to the FZ6-R's mirrors. Modification is needed (drilling). So the Mirror block offs won't bolt on without modification either.
I picked up a set of ZX-6R block off plates from Cycle Gear when I put my bar end on. $25 I think...
$14 isn't bad though. The only problem with the ones I got is that the posts are a little on the short side so I couldn't tighten the nuts down as much as I wanted to. Other than that it was a great fit.
