For the past couple of days I was researching what coolant to use to replace the original one.
This is what the service manual advise:
Yamaha Motor Corporation, USA - Lubricants & Grease Yamacool High-Performance Antifreeze.
Also I found the following articles helpful:
Antifreeze/Coolant-Brand - Yamaha FZ6 Forums - International FZ6 Motorcycle Community Forum
Choosing silicate free motorcycle engine coolant for Honda motorcycles
Safe options for the FZ6R, other then the Yamaha OEM, I would consider in the future:
AMSOIL Antifreeze and Engine Coolant ( ANT1G-EA )
Engine Ice
Evans NPG+
I will update more info as soon as I change the coolant (if time allows it maybe do a quick How To).
I still haven't picked one, but it looks like I will go to the dealership and get 3 quarts of the OEM one (Yamacool High-Performance Antifreeze - ACC-YAMAC-L6-W), it's the cheaper way.Recommended antifreeze
High-quality ethylene glycol antifreeze
containing corrosion inhibitors
for aluminum engines
Mixing ratio
1:1 (antifreeze:water)
Radiator capacity (including all
routes)
2.00 L (2.11 US qt, 1.76 Imp.qt)
Coolant reservoir capacity (up to
the maximum level mark)
0.25 L (0.26 US qt, 0.22 Imp.qt)
Engine Ice
Evans NPG+
