Vibration at 6000RPM
Ryan Coward
Hey Everyone
My FZ6R seems to be in good shape, its my first FZ and have owned it for about 5 months. Ever since I'v had it its has a vibration from 6000 up. It revs right though to redline with no worries but it just develops a small vibration at 6000 and remains constant through the rest of the rev range. The vibration is there while riding and just free revving. It does not make a noise or get worse while the revs get higher, this may be normal the for FZ6R motor but I just want to nip it in the butt if there is an issue.
Can anyone please offer some wisdom.
Thanks everyone.
BluePill
The Fizzer is a very smooth bike, but some vibration is always going to be there. If you are feeling it mostly in the handlebars, not in the footpegs or seat, a good trick is to fill the handlebars with steel BB's. Remove the right side bar end weight (it unscrews) and turn the bars full left, to bring the right end of the bar to its highest position. Pour the BB's inside until it is full.
Spartan
That's sounds about right, its just a part of the XJ/FZ's "character". Any write up on the bike you will find some mention of vibration around 6k. It tends to drop off a little around 8k i find
That being said, still do your standard maintainance, check everything is properly secure etc.
AL72
One day I went out with a friend with a motorcycle with smaller displacement (250cc) and I was riding at 5,000 RPM range and I noted those annoying vibrations and my hands got numb. It is more comfortable to ride at more than 7,000 rpm.
Regards!
