cbzdel
Who has rode two up on their FZ6R???
I just did and it was hard to get used to at first (first time I EVER did it) it was almost like learning all over again.. I thought I was going to burn out the clutch trying to go from a stop up a hill hahah!! But after about 15-20 minutes I got used to the weight and started to loosen up a bit...
I added some PSI to the tires like the book says (actually I am 200lbs so I should of been at a higher PSI from the beginning haha) then I set the spring to the number 7 setting. I got on the bike and it was so stiff it didnt move haha, then the woman got on, she is only 140lbs, so total weight was 350 total including gear...
OMG I thought I was going to be sparking and scraping on everything!!! It felt like the bike dropped a solid 3-4 inches! I am just making sure this is normal, because the weight limit is 400ish lbs and I didnt think the bike should drop THAT much...
