So I finally finished wiring my aftermarket turn signals. Smoked flush mounts up front that I purchased from Cycle Gear, and the clear lense arrow style signals that came with the Competition Werkes fender eliminator kit in the rear.
What I did to connect them was use the original turn signal connectors by cutting the wires a few inches short of the connector, and then crimping them to the aftermarkets.
Everything lights up perfectly although there is the high rate of flash. But what I noticed as I left the blinkers on while I walked around the bike for 20 or 30 seconds to check them out, was that the rear signals from the Competition Werkes kit were emitting some kind of smoke from the lenses. It's a very small amount, but I notice if I leave the rear signal on for more than 10 seconds or so it will start to emit a small streak of white smoke?
Could this be from the high pulsating flash rate ( the rears use a bulb not LED I think ), or could it just be a case of cheap rear signals? I would like to not think it was the wiring as didn't do anything different connecting the fronts and the rears but who knows.
Any advice at all would be appreciated!
