valve stem caps that monitor tire pressure....These are a easy way to
check pressure before a ride. They are made by bike master. the valve stem caps are sold for certain pressures and they have a band that changes color if the tire pressure is low. Green is at the proper pressure, yellow is -25% low, red is -30% or lower.
Has anyone ever tried these...I thought they look interesting so I figured I would try a pair so I bought the rear rated to 42 Psi And front rated to 38 Psi.
I still will check with a good Pressure guage but I figured in between throwing a real guage on it is an Easy way to get a quick visual.
