Thoughts On Shift Points?
Comiha22
Just curious as to how people feel about the recommended shift points in the Owner's Manual.
1st > 2nd: 12.5 mph
2nd > 3rd: 18.8 mph
3rd > 4th: 25.0 mph
4th > 5th: 31.3 mph
5th > 6th: 37.5 mph
I personally think 1>2>3 seem ok, but 3>4>5>6 seem pretty low to me. I feel like the bike likes 3rd gear up until about 40mph. That said, I'm (1) new to motorcycling, and (2) am still in the very early stages of my break-in period (only 70 miles in), so I may not be seeing the whole picture.
Thoughts?
G
Ghost Weim
1st > 2nd: 12.5 mph
2nd > 3rd: 18.8 mph
3rd > 4th: 25.0 mph
4th > 5th: 31.3 mph
5th > 6th: 37.5 mph
Thoughts?
I agree. The 3>4>5>6 recommendation seems low in my mind. I tend to shift in the 5-6k range like Fz6nick says.
O
oldfast007
Even more importantly (IMO) try to always vary the rpm's don't drone along at set level for too long, as far as the shift points, I to would go slightly towards the higher points. Enjoy:thumbup:
I'm a new rider and still in break in, only 32 miles on my bike and I shift at 4,000 RPM and only got it to 4th gear at about 45 MPH.
S
SovietRobot
My shift points are never the same.
I never even look at the tachometer anymore.
I always keep the gear and RPM appropriate for the situation, which can change rapidly.
S
scottsst
I have always thought the same thing its fluid thing saying that you need to shift at a given speed is BS go with your gut if you feel its time to shift do it .you can always go back a gear if its not right
I know a few guys who red line every gear before they shift. I feel that does harm to the engine but it's there bike not mines.
S
scottsst
that is hard on an engine but at the same time not running it out every once and a while is also bad
F
fz6nick
It all depends on how long they hold it at redline, and how far into redline they go.
I ride hard almost all the time. this conists of shifting near redline a ton. It will not hurt the bike at all if you do not bounce it off the rev limitor.
rleckert
1st > 2nd: 12.5 mph
2nd > 3rd: 18.8 mph
3rd > 4th: 25.0 mph
4th > 5th: 31.3 mph
5th > 6th: 37.5 mph
Thoughts?
I got my 6R about a month ago, and had the same question - not only with the shift points you mention, but with the recommended downshift speeds as well, they didn't make any sense at all (when I showed the dealer he couldn't believe that was in the manual). I have found this bike shifts great around 6k, I am still working through the break-in period also so I haven't pushed it to much beyond that.
PrangeWay
Yeah I'm still in break in, shift at around 5500 or so. Though I have spent some time shifting at 7k-8k and the bike performs alot better/smoother, but obviously have to be post break-in b4 that's the norm.
Ok so if your bike red lines at 12,000 RPM then shifting at 11,000 RPM should be fine I take it.
The manual also states to down shift to 1st at 15 MPH. Which I have tried from 4th gear and it is a lot smoother than if you shift at a higher speed.
F
fz6nick
If im riding through town (speed limit 30mph) I will be in second the whole time. Going from a stop to highway speeds its redline time.
When slowing down from highway speeds to a stop, I will blip the throttle at 5k rpms in each gear. Not only does it sound good, you will use more engine braking, and it is a lot smoother
T
thirty_too
i shift around 12k regardless of the gear... i want to be in the power band as much as possible... 1. its fun 2. safer, can get away from cagers
T
thirty_too
i run in 1st or 2nd going through town... obviously you cant be in the power band going 20-40 but the higher my rpm's are the more response from my throttle i have... that and i have the 2bro and they sound fantastic going through town at high rpm's
cbzdel
Something I have noticed.. When I am in 6th on say the freeway and come to a slow due to merging traffic say I get down to 30ish.. I can gun it in 6th from 30 to 70+ with just a minor twist of the wrist, not even trying to push it. Maybe its just because its my first bike, but I feel like I have PLENTY of power in 6th gear, still faster than any car.. I am honestly comfortable doing that, I have no problem staying around the 5k-6k (or higher) area either, depending on what I am doing..
Edit: I lied!! I tried it today and it was slow!! Well faster than my 71 slug bug but you get the point haha.. I must of been in 4th or 5th and "though" I was in 6th for some reason!!
MNDZA
I don't follow any shift points. I just do what the situation calls for. If I'm in moderate traffic and want the ability to move quick if need be, then I hover around 5500rpms. If I'm in a chill situation, such as a one lane road and got cars in front and back, then I'll be around 4000rpms. I usually shift at above 7000rpms though.
