Sprocket help
JekyllandHyde26
Ok, so i read all about the sprocket changes and how it affects the bike and i want to change it to 15t on the front and a 48t on the rear. What my question is, what sprocket to get for the rear because all the online stores say that a 48t sprocket does not fit my vehicle. Is there a certain one that i need that fits or will any of the 520 48t sprockets work?
I had a temporary steel 49 T on there once. You could go even more teeth without needing a new chain, but you'd have to push the wheel up on the chain adjustment the more teeth you select on the rear.
I think I chucked it when I was moving house, I remember doing some Xena-esque Kung Fu moves with it last time and thinking about cutting them in half and sewing them onto my jacket like Blackie from WASP, except he uses power saw blades. I must have been feeling lawless at the time.
