Softer shock?
Just_Jim
Adjust the shock pre-load setting to the softest (1) and go from there.
BluePill
Unless you weigh less than 175 pounds, all you do with a different rate spring is screw up the handling. The rear will be prone to loosing contact on high speed curves with some ripple in the road.
BGWATTS
The way the bike is getting ridden....getting into adventure bike territory. Tons of miles on gravel levee roads ....want to try a "softer" rear end. Looking for source for appropriate shock or spring for existing shock.
