Grabbed a front and rear set of black anodized r1 pegs on ebay for cheap (total for both was $16) figured hey why not give it a try.
Only issue I found was I couldn't use all of the hardware that came with the pegs, had to reuse the front pins, but had to buy bolts nuts and washers for the rears.
The rears need two washers on top and the bracket will flex a bit to get tight. I'll probably hunt down a pin long enough soon. I want black pins.
No slop on either set, went for a 20 min ride and no added vibration, no need to adjust the shifter or brake pedal either.
Anyhow, picture
Anyhow, picture
