Hey everyone,
was doing a little reading and found out i never set the accel pump on the PCV map when i downloaded everything.
I found this post thanks to Marthy on how to do it.
once you put those in press okay and send the map. i havent got to go do a test ride yet so results will follow.
here is a picture of the setting typed in how you will see it. this is where the 75,30,16 come into play.Go on my website under tech support and download Advgear RevB. If you didn't connect the speed sensor to the PCV use the Sport or Touring RevB.
For the A/P go under Configure, feature and enable the A/P and click on the icon on the right side to set the parameter. (75, 30, 16)
save...
