UncleHilty
Hey everyone, just a bit of advice if you plan on doing your own oil changes, get rid of the stock oil filter and get the K&N #204 with the bolt. It will make you life and oil changes soooo much easier. Last night I did battle with the stock filter for over an hour after two screw drivers through its little body it finally relented and all is well! First time I ever had a problem with the stock, but it will be the last!
