erionalite
any one has a howto list of how to remove the break pads of the fz6r ?
- Erion
- Erion
I don't think that there is a how to...but a search would give you everything that you need to know. I remember when I did my brake pads, it took me a few minutes to figure it out. You actually have to pull the caliper mounting bracket from the caliper a little bit in order to get the pads out the back...it is really weird, but after a few minutes of messing with it, it isn't too bad. If you have ever messed with brake pads before it should be no problem for you.any one has a howto list of how to remove the break pads of the fz6r ?
- Erion
I am totally agree with Marthy, you should have to take in to the bike shop, they will remove brake pads properly, but be sure that brakes are important for you.If you don't know maybe you should bring it to the bike shop. As a rider I agree that you need a minimum of mechanical skills to make sure everything stay in place. But for your own safety, please don't get there. Brakes are kind of an important feature on your cycle. If you don't put them back together properly it will end up in a bad ending story...
