For those who want a brighter halogen headlight, the PIAA extreme white plus is on sale. Best price I've seen for this bulb. Will try pics when installed.
Motorcycle Bulbs | Motosport
Being seen regarding lights is a question of brightness, color, and movement. The HID option is brighter, with a higher K possibility (whiter, bluish white) color. The PIAA bulb is brighter and made better than stock, (quartz glass) , coatings, etc. (Movement is done with a modulator.)ok whats the difference between the HID and the PIAA, they siggested a put a different bulb in at the dealership but which one is actually better seen and how easy are they both to install?
bump to repostNight time run in neighborhood, low beam gives better light and penetration 2X better than stock. At high beam even better, maybe 3X better, deeper field of vision and clearer as the whiter light is better for definition. Overall a measurable improvement over stock, especially at night.
Just took it on a longer night time ride including freeway and a short winding road, ( 9PM and dark, cold!). Change of opinion PIAA bulb is better than stock but: low beam = better contrast, range moderately better, high beam = better contrast, better range, twice better. If brightness is of major concern go with HID. (Will check and probably raise LB height.)
