The LED's shouldn't conduct when reverse biased. They just won't light. Pinched wire maybe or shorted LED assembly?wires are backwards or bunk lights... my guess is bunk lights because i dont think backwards wires will blow the fuse...
My guess is the problem lies somewhere around that slice...either that or changing both front and back blinkers together is causing the problem. On mine, just changing the fronts caused my signals to flash faster due to the difference in resistance. So maybe changing both with non-stock resistance bulbs causes the circuit to be way off what the fuse can handle.the rear i had to slice
This should be pretty simple to find. It's probably something that has nothing to do with what modification you were doing since you've checked the wires associated with your mod. I don't have the time right at this moment but in a couple of days I'll be able to look in the manual or a Haynes schematic to try to help. Look at the wires at the handlebar.any more suggestions?
