I just completed a project I have had in mind since I bought the 6R. I'm a believer in day time running lamps. Even though motorcycles run with the headlight on at all times, anything that can help cagers see you coming will help prevent them from turning left in front of you. Since the 6R has a limited electrical generation capability, I went with super bright LED's. They draw milliamps and give off a lot of light. Over the years researching daylight running lights, it has been considered best that they form a triangle when viewed from the front (unlike the Harley crowd that places them side by side with the headlight). Hence I put the new lights down on the forks. Another bonus for the LED's is they are very light weight. They add a few grams of unsprung weight to the forks, instead of pounds like some other lamps. Unsprung weight is one of those things that can have an effect on the fork action. I made my brackets out of scrap aluminum flat bar, 1.5" wide. Stainless steel would probably be better but I didn't have any handy. Aluminum is easier to drill holes/shape then SS is also. Here are a few photos of what they look like. If I can figure out how to post them.
