Long story short, took a corner wide on a track day and literally got stock in the mud. Ended up laying the bike down on it's right side at about 10 mph. I had to power wash the the bike, like hard core. There was mud EVERYWHERE, inside the fairings, inside the wheel wells even in the bolt heads. I meant to lube the chain after, I really did, but was busy for nearly two weeks. So today I go to hand wash the bike, toothbrush and all, to clean the mud out of those hard to reach places.
Then to my dismay I saw rust on the inside of my chain. I sprayed the chain down with [ame="http://www.amazon.com/DuPont-Motorcycle-Degreaser-Sprockets-11-Ounce/dp/B003OBM5EQ/ref=sr_1_1?ie=UTF8&qid=1449708040&sr=8-1&keywords=dupont+chain+cleaner"]Dupont chain cleaner[/ame], wiped it down and then lubed it.
My question is this, is my chain still good? I was taught that the metal is less important than the o rings. So if the o rings are lubricated and the chain isn't damaged or kinked then I'm fine, right?
