ajskillz13
I would appreciate any feedback from Arai helmet owners...
I just tried out my wife's new Signet Q on the way into work this morning to see if I liked it any more than my Bell. It is definitely comfortable and light, but I noticed a TON of air flow inside the helmet... to the point of being annoying.
First thing I did was lock the shield down and double check all of the vents on the front. They were all closed. I noticed that when I tilted my head down, I got a huge rush of air from the top of the shield.
Obviously, my first thought is that the shield is not sealing properly. However, I don't notice any breaks in contact with the seal and when I blow into that crack, it only fogs above the seal.
Am I crazy to think that with all vents closed and the shield properly installed, the helmet should be fairly quiet with very little air flow? My Bell sure is like that. It will move air when you need it, but it seals when you don't.
My wife mentioned this extra air flow, but I assumed it was from under her chin. She loves the fit of the helmet so much, the only option is to figure out how to fix this. There's no way we can ride on a cold day with this.
:surrender::surrender::surrender:
