Final Impact
FWIW on the older sibling the FZ6 the solid blue is power, black w/blue trace is the ground for each sensor like the speed, TPS, lean angle all get their own color like green, yellow, pink, grey... etc which is the data from those sensors.
That said, I would venture to guess the R follows the same logic. Just look at the what is common to all sensors and you should be able to figure it out which wire you need based upon its physical location on the engine or transmission in this case.
Yes, O2 sensor must be unplugged or the ECU will be attempting corrections to your map.
