Id be interested how the fitting goes. Also if you have a link that would be helpful. Im thinking of getting a set myself.
Looks very similar to the red ones I got. Watch out for fading.
Thanks for the link!A Pair CNC Brake Clutch Levers Yamaha FZ6 04 10 FZ6R 2011 2013 | eBay
I'm buying a small tube of grease tomorrow so they're well lubricated in the moving joints where the bolts go through.
This is why I've been reluctant in getting them so far. Would be good to hear the OPs experience in installing them.Not to sound rude but how can you rate levers just based on looks? You should probably put them on and make sure they fit good and function well.
Sure, they look nice, but if they don't work good then it's kinda pointless
Took no more than a few minutes to fit them mine aren't grabbing any brake at all which is lucky by the sounds of it
You had better get them checked by a professional moto mechanic!
YOUR BRAKES ARE SUPPOSED TO DRAG only slighty but they should always have contact
