SoCal600
so right now i have a little over 58k miles on the bike and its been running great
already have the r6 header and aluminum muffler, K&N air filter (still need a juicebox) but i really been thinking about trying to change out my throttle body. one mod i recently done is i bought a spare fz6r air box off ebay and changed out my intake tubes to all matching short tubes. shorter tubes will live up the top end of the bike (which it did some) the power band pulls a tad stronger now. but with the research i did i found out that the fz6 uses the same fuel injectors, wiring, and fuel rail. i think if i was to pull off the rubber boots on my cylinder head and install the fz6 ones, take out my throttle body intake tubes from my air box and hone out the air box to allow me to fit in the fz6 intake tubes and install the fz6 throttle body, i will have a fz6 throttle body 36mm vs 32mm and everything electrical is plug and play. throw in fz6 cams and take the cam gears to a machine shop to be slotted so i can have varible cam timing and adjust the overlap. what do you guy think ? less than $100 for a fz6 throttle body and prolly $50 for the intake tubes and cylinder head boots.
