Got my pcv put in my bike and not impressed at all!!! All I have is a drop in k&n used the stock map from power comander and lost a lot of top end. Any one have a map for stock exhaust and drop in k&n?
the PCV alone will give you NO extra power
the only reason you get a fuel controler is to give the bike more fuel you cant do that with the stock ecu
the stock airfilter and ECU are fine... stock
the exhaust is quite
quite = power loss
i mean come on did you think explosions were quite lol no they make them that way and lose power in the process
get the FULL TBR exhaust (because yes headers make a differance) or the marthy exhaust and feel the true power of the FZ6R
IN the mean time Marthy, which one of your maps would he most benefit from with a stock exhaust over stock PCV map?
and, BTW, the stock air filter is already a high flow filter... it just doesn't say K&N... so you won't see any change there.... only advantage of K&N is cleanable/reusable...
Do the Marthy exhaust, do the AIS blockoff then his maps then you'll see gains... free flow and about 5-10 lbs lighter
Oh ya... Try them all and compare them. You can download them from my website under tech support. The Sport or Touring RevB has been one, if not the best base map for the 6R. You can start with those first...
If you have your PCV already all you need is the exhaust mod and BOP. Your looking for around $525.00 with shipping.
Look at the website and choose the slip-on that you want then PM me with your choice and shipping address. I will quote you accordingly.
