How do I pull fault codes?
Talk nice to your bike and it will tell you. LOL! There is a way to bring them up, but I don't know it. I can look in my service manual.
Yeah, I hear ya. I initially thought my problem was fuel system related, because of the gas cap problem. After getting lots of input (especially Marthy's) I have narrowed it down to a timing issue. Ordered a new cam tensioner. Need to tear down to check timing still though.I'm thinking with the bike running strangely and then dropping the speedo, it must be something with a speed sensor or maybe a wire got snagged and chewed up or something. I'll try to find time this weekend to break the bike down and search.
This happened right after I got my bike back from the shop getting new tires, but I don't want to blame the shop. Hoping just a coincidence.
That's good news. Keep at it. I don't think yours is timing, just ranting because mine is f'd up.It's hectic right now. As a music teacher ending the school year I've done 2 concerts and have 8 more in 3 weeks, then graduation, grade book, and nailing down summer employment.
SOME PROGRESS!!
I forgot to pull codes but went over the bike yesterday, every wire I could find. Plugged and unplugged everything electrical. PCV was unplugged but I left power, ground, and speed sensor wire. I took the tap out of the speed sensor wire, spun the wheel on the stand, and the speedo worked! I pulled back the insulation on the wire and made a clean connect without using the tap. DAMN! PCV really does add a serious amount of power!
Bad news, still dropping power in the same spot most of the time. If I shift quickly I get a few seconds of that power loss even into the next gear, even at much lower rpms. Sometimes I can get it to redline in second gear, but most of the time there is a mighty loss of power around 9k.
Really feels like my GS500 and my wife's Ninja 250 when one of the main jets got crap in there. I added Lucas fuel treatment last time, but that's known to be a safe cleaner. Now I'm gonna add some Chevron Techron when I fill up tomorrow. I don't think it's gas related, but it's worth a shot! If it doesn't clear up, I'll empty the tank next time it gets low just to cross gas off the list completely.
DEATHMAGE
Think I'm gonna have to take you up on that in a couple weeks
SCOTT
I hope mine isn't timing, don't see how it could be. Hope you get yours figured out!
Yeah Scott I'm almost positive mine has nothing to do with timing... but since I can't find the issue I can't take it off the table. Bike has less than 10,000 miles on it and I didn't have this issue last season...
I'm gonna try to pull codes and change the oil this weekend. At least it's functional and safe for the road (I think) but I'm still :banghead::banghead::banghead:
Thought of something. Kinda thought it might come to this, but it's a pain in the @$$ to do.... spark plugs. Right before winter I swapped in some iridium plugs. I think I could get to redline before Christmas but I can't be certain.
Damn.... I'm gonna have to swap plugs again. Anyone want Iridiums with under a thousand miles on em?????![]()
did it work???????????![]()
Oh shit sorry. Yup, swapped in some non Iridium plugs and bike works great. Never going back!!
Glad you found the issue.
That said, it really sounded like the fuel pickup strainer is plugged and its starving for fuel. WOT takes the most volume and debris in the tank could be stuck on the filter limiting fuel flow.
Any chance all the times the tank was lifted it rinsed itself clean? Next time you run the tank down low take a flashlight and look inside for rust.
What was the plug gap on the iridium plugs?
Also, could you add some detail about what it really did? Are you saying it was like turning the key off until it got back to 9k and then its comes back to life only to misfire/shutdown again?
Last thing; if you ever need to do a quick FC bypass, just unplug the injector leads from the FC and connect the OEM plug into the injectors and it will run from OEM ECU map assuming all of the connections are good.
