dustinsf81
I installed new flush mounted turn signals and a fender eliminator with new turn signals. The fronts were 2 wire plug and play while the rear had to be cut and crimped. After finshing the install I noticed that when I signal to go right, both right side signals flash at the day time running light brightness and the left sides (which should not be flashing at all) are flashing at the turn signal brightness. The same thing happens if I turn to go left.... I have unhooked the fronts and rears to see if one is causing the other to malfuction and I get the same result... I'm lost and need some help asap!!!
Thanks in advance,
Dustin
Thanks in advance,
Dustin
