Y
yellowfz
Yeah I am going to cut the pattern piece in half so as to have a top and bottom half and dowel pin them for alignment, same for boxes will dowel pin them too, I still need to add a couple of latches to the mold boxes to hold them together so the metal pour does not separate them .I think you might be running into an issue with the curvature of that back piece. You might have to make that separate and bolt the 2 pieces together once done. Looks to me like too many angles to be able to pull the blank out before you fill the sand with aluminum.
You are working to do a poured piece of aluminum still, right?
Just seems like this is going to need to be a part that takes a couple pieces vs just one.
