If you hate the popping sound on decel then you should get Smog Block off plates.
Graves sell them for 34.99 + shipping but I found someone who sells them for 20 + shipping and their basically the same thing but don't have the graves G on them.
rothjl749 Of R6 Forum said:I am selling smog block off plates. They are almost identical to the Graves plates. The main difference is that Graves' sells them for $34.99 + shipping and mine sell for $20.00 + shipping. These smog plates are also 25% lighter than my previous version. If you have any questions about them at all, feel free to pm me. Also, if you would like to place an order you can purchase them at Roth Industries — Welcome
You can also check out the many reviews on the R1-Forum website at this link FS: 04-08 R1 Smog Block Off Plates - $20 + Shipping : Yamaha R1 Forum
Item: Smog Block Off Plates
Application: Yamaha R1 (04-09) / R6 (03-09) / R6S (06-09) / FZ1 (All) / FZ6 (All)
Description: Smog Block Off Plates are designed to seal off the ports on the valve cover used by the air injection system (a.k.a smog pumps or AIS).
The air induction system (AIS) burns unburned exhaust gases by injecting fresh air (secondary air) into the exhaust port, reducing the emission of hydrocarbons.
Once these are capped off the air injection system can be safely removed. These Smog Block Off Plates are made from CNC'ed billet aluminum. There are two reasons why you want to remove the air injection system from your bike;
1. If you are using your motorcycle on a closed course (racing, track days, etc.) you will want to remove all unnecessary equipment from your bike for reduced weight and ease of maintenance.
2. To get an accurate Air:Fuel (A/F) ratio when dynoing the bike. The air injection system pumps fresh air directly into the exhaust stream in order to burn off any unused fuel. Unfortunately by doing this the A/F ratio is thrown off by the extra fresh air in the exhaust stream. By removing the air injection system you can achieve an accurate A/F ratio.
Sold per pair.
