Hello , I just purchased a 2012 FZ6R and am learning the ropes as they say steadily in regards to winterization. I live just south of Buffalo NY and so even now the low forties and thirties are here. I've been able to get a handful of rides but the weather seems to be taking a serous dip. I have checked the oil and it appears clean and full but I know the information I have read recommends a oil change . I looked at the oil drain plug and am concerned about its current state - fearing it maybe a bit warped so I ordered a new drain bolt but it will take a few more days. I have filled the tank and gave it the recommended amount of Stabil , have it connected to a battery tender , cleaned and lubed the chain. and made sure the tires are fill to specs. I even have a Pitbull stand holding the rear and card board under the front tire to avid contact with the cold cement. The bike is in a closed garage which is not heated but no wind can get to the bike and a cover is applied over the bike. is the delay in the oil change a serious issue ? I would like to change the coolant even though it shows full, (test I did says 3 balls floating or negative ten ok) and bleed the brakes but I thought the oil change would be more priority. Can others tell me if I'm heading in the right direction wit all this ? I plan to have mechanic look over the bike good in the spring. --- thank you for any thoughts
