Installed my exhaust over the weekend and I LOVE it! My bike finally sounds throaty at low RPMs, and the mid-range torque from the PCV map blew away my expectation. Thank you Marthy!
That said, I do have a noob question... now my exhaust pops a lot on sudden deceleration. I figure that means I need to either...
1. buy new header gaskets (or tighten a bit more to crush the old ones)
2. somehow seal the AIS block off plates that I installed, if they're leaking
3. disconnect an O2 sensor (I'm not aware of this being needed on the FZ6R though)
4. mess with the PCV map (either to lean it out when accelerating or fatten it when decelerating, IIRC)
Any thoughts on this, guys? I figure the Adv Gear Rev B map would be fine, so I'm hoping I don't have a leak! I know popping goes hand in hand with aftermarket exhausts, but I didn't expect this much with the block-off plates installed. I like the sound though, so I won't be too worried if I can't figure it out![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
