How to Properly Winterize Your Motorcycle - Yahoo Voices - voices.yahoo.com
Some pointers to keep your bike happy come spring.
Going to have to remember that this is here, but I'm going to ride this thing until I can't ride it anymore >.>
Virginia gets cold as hell sometimes though
Pretty much But it's started to get a bit chilly in the morning/evenings here already. Easily in the high 40's low 50's, not including any wind. Dunno about some of you guys, but I'm pretty cold natured, so I get cold eeeeeasy
Good article, thought I'd throw this Q out there for discussion...
He says change the oil before winterizing, but you don't need to change the filter until spring time when you de-winterize... so he suggests changing the oil so the bike can sit around all winter, then change it again before you ride, so I'm basically wasting an oil change?
...I know it's not a very expensive thing to do which isn't the issue, but I do have 2 bikes to winterize, last year I put both bikes up on stands with the oil I was previously riding with, come spring, took them down and rode until I hit the mileage for the next recommended change, and went from there. As it stands now, I've got a couple of months left to ride, probably won't hit enough miles to make the recommended change, so I was just planning on doing what I did last year...
Any issue with that? Is there any damage done by riding with the oil that's been sitting around in the engine over the winter months?
I don't understand, what would be the point of putting new oil in if your not going to start it or ride it its not going to go anywhere but just sit in the reservoir.
I guess this: "Used oil will become acidic and break down when not in use over longer periods of time" which I've heard before, but doesn't worry me enough to change it in the fall, I just change it in the spring with a new filter and good to go.
Just a precaution. I would highly recommend changing before winterizing. That would be the important one. Toss up if you should change again come spring. Up to you.
One thing I may change... Maybe start the bike up with the new fresh oil just for a couple seconds to get that new fresh oil throughout the system. Then let it sit.
Winterizing your bike in the UK:
Stick some rain tires on it and spray it with ACF50 to protect. Then buy some waterproof textiles.
I bet half of your winters is nicer than our summer!
This is me last year after an 80 mile commute:
I say bring it on
wow, I wouldn't even go outside in that. never mind get on my bike. god I love so cal!
