This, I do it too and it can be fun. I do wait until I know that day it will stop raining because it's been like here for a couple days straight.A good rule of thumb is every 600 miles and whenever the chain gets wet (riding in the rain or washing).
I do mine weekly, after a decent ride (300km+) or when the bike gets wet.A good rule of thumb is every 600 miles and whenever the chain gets wet (riding in the rain or washing).
I think it's too much excess lube when it flings all over your pant leg or onto the tire.I do mine weekly, after a decent ride (300km+) or when the bike gets wet.
Doesn't take long & you really can't over lube.
I did mean you cant do it too often. Didnt mean an excessive amount of lube on the chain.I think it's too much excess lube when it flings all over your pant leg or onto the tire.
I actually bought a cheap leaf blower just to dry the bike off quicker! Really works & gets water out of the places you can't get to with a chamois.3. Wash the bike like normal and rinse it off. Try and get it dry as quick as you can
Thats a great write up, thanks! However I do not have a center stand, so what is the best way I should apply the lube?I lube mine every time I wash it. (I don't ride in the wet) Which with all the bugs lately is pretty much after every ride. I've kind of got it down to a perfect routine.
1. Put the bike on the swing arm stand and while turning the rear tire backwards, soak the chain in Maxima CleanUP Chain Clean. This stuff is awesome but it's pretty nasty so I try and do it outside the garage. I also use gloves and eye protection. No need to scrub with this stuff. Although I do use a brush to clean the sprocket a bit once this stuff is all over it. Just be liberal with it. Let it soak for 5 minutes. Keep spinning the rear wheel from time to time while it soaks.
2. Take the bike off the stand and wet the bike down, running A LOT of water over the chain to get all the cleaner and the crap it's taking with it off. You'll be amazed how nice and shiny silver your chain all of a sudden is.
3. Wash the bike like normal and rinse it off. Try and get it dry as quick as you can so you can get the bike back up on the swing arm stand. (I washed the bike while up on the stand one time. While it was nice having it perfectly upright and such, it felt like it was a bit unstable being wet. I wouldn't recommend it.)
4. Once on the stand again, wipe any excess water off the chain with a dry cloth. I even hit the chain lightly with some compressed air to make sure it's completely dry. I then use PJ1 Blue Label Chain Lube. (This so far has been the cleanest stuff as far as not flinging off.) Spray it on while turning the tire backwards for two full cycles of the chain. Wipe off the excess and you're good to go.
I suggest getting a stand. Harbor Freight is the cheapest around $40 and it's well worth it.Thats a great write up, thanks! However I do not have a center stand, so what is the best way I should apply the lube?
Go buy one. for $40 at Harbor Freight like Mike mentioned, there's no reason not to have one. It's a necessity if you have a chain driven bike without a center stand. I tried the clean one section at a time method. After 10 minutes I got in my car and drove to Harbor Freight, picked one up, drove home, cleaned the chain properly, and was done before I would have been if I'd kept going the hard way.Thats a great write up, thanks! However I do not have a center stand, so what is the best way I should apply the lube?
