Removing rear wheel
jgelack
Hi, I'm mounting a new rear tire on my bike and was wondering if I HAVE to loosen the chain adjuster bolts to do this, or can I just loosen the axle and slide it out? I appreciate any advice you can give me.
mike
You don't have to loosen the bolts to side the axle out but its going to be hard to put it back in while trying to pull the tire back and installing the axle and adjuster blocks at the same time. it would be alot easier to just loosen everything up and then adjust chain tension.
RavenriderFZ6R
How to video
Here is a step by step video of how to remove the rear wheel and tire assembly hopefully it helps some riders out there. I'm a former U.S. army helicopter mechanic and work as an entry level car mechanic at a dealership hopefully this helps somebody out there. I done all the work on my motorbike soo far so like I said hopefully this helps a DIY'er out there.
https://youtu.be/vDtZBu1GjR8
