Hi!
I have a 09 FZ6R and my motorcycle did not start yesterday. I suspect it is due to the battery. Is there any way to check this using a multimeter? If so, what reading should the multimeter show to confirm my battery charge is depleted?
Nextly, I have a Battery Tender and plan to use to charge the battery. How do I use it?
[*]Should I select 6V or 12V on the Battery tender?
[*]Should I connect the red clamp to the positive side of the battery?
[*]What about the black clamp? Does it connect to the negative side of the battery or should I connect it to the chassis of the motorcycle?
Please help. Sorry for the dumb question.
