Just browsed through threads that discussed tire pressure. It's known that that Yamaha is recommending 33psi front and 36psi rear for rider weighing 198lbs and below, and 36psi front and 42psi rear for riders weighting over 198lbs.. but.....
Anyone ever questioned why there's such a big jump between the recommended pressures?? I weigh about 200lbs with gear on, does the extra 2lbs magically means the bike should run 3 and 6psi more on the tires??
What i'm trying to say is that there doesn't seem to be a progressive scale for weight vs psi... I'm hoping people in the know can chip in here..
