Header Stud's
bleedinblue
bleedinblue
Careful when using an easy out. The machine shop that did the motor in my truck needed to use one to remove a stuck oil plug. They ended up cracking the boss around the plug. Cost me $200 to have the cracks welded. It sometimes may be best to remove the cylinder head. Then drill the bolt out on a drill press using a vise.
Y
yellowfz
I'll be sure to do that, thanks Yellow.I read that some oem studs come precoated for a single use, but none of them say for sure so id rather take your advice then have a nasty suprise in a couple of years.
Not that I have ever seen, but not to say it has not changed over the years.
YMMV
