[email protected]
Parked my motorcycle up against the curb put the kickstand down and it shut off as it should went back out several hours later to go home and wouldn't start. But it started and ran in neutral. I cut the wires at that the kickstand sensor and join them together still wouldn't start. Came back a couple days later tried again it still wouldn't start remove the kickstand sensor all the way up to the blue plug under the gas tank jumper it just after the plug still wouldn't start. I removed the cluch plug and jumper those wires together as well still no run. Can anyone help me out.
