What map should I run with a Delkevic System??
Xtom
So I just installed my Delkevic full system and I'm wondering what map would be best to use, my only mod is the full system, the intake and air filter are stock
im Sorry! I’ve been away from my laptop. Download sportRevA map and look in the zero percent column, the vertical column all the way to the left, the map I’m using does not have zeroes going down, there’s positive values. I believe I’m running Revision A map.
Xtom
What's the difference between RevA and RevB?
If we’re speaking about just the maps and not the Advanced Gear maps..I believe the RevA and RevB differ in the ZERO throttle percent category. The far left vertical column. He toyed around with fuel trims (adding and subtracting) in an attempt to alleviate decel popping. Which, I don’t have block off plates and I’m basically straight pipe running RevA, my pops pretttty bad...
Xtom
Ok so revA and revB are the same performance wise? But it will pop more, which probably does matter since I have diy block off plates. Would be nice to have Marthy clarify things for us, but hes probably been off to other things lately.
