Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 9 of 9
Thread: Rear foot brake lever adjustment not holding?
  1. #1
    Senior Member sti491's Avatar
    Join Date
    Oct 2017
    High Point, NC
    Posts
    281
    Rep Power
    2
    Default Rear foot brake lever adjustment not holding?
    I needed to make some adjustments to my shifter peg and rear brake to get them where I like because I have big feet/long legs.
    I needed to adjust my foot brake lever so it was higher. I adjusted it enough I needed to also adjust the brake light actuator. I use my rear brake some, but not a lot, favoring the more significant weight shift strength of the front. Emergency braking I grab a bunch of both! I lightly use the rear brake mostly for slow speed maneuvering.
    My favored adjustment is getting near the end of the higher setting (I think). It's great just after I set it. But eventually, I am pushing it too far down again for my liking. It is not brake fade. I only street ride and no way I am getting that rear disc very hot.
    Anyone else have an issue with the rear brake not holding it's adjustment?
  2. #2
    Senior Member MrFrzZ's Avatar
    Join Date
    Mar 2016
    South Carolina
    Posts
    155
    Rep Power
    3
    Default
    Does the pedal seem to "reset" itself each time you ride? Or do you have to re-adjust after each trip??
  3. #3
    Join Date
    Oct 2017
    High Point, NC
    Posts
    281
    Rep Power
    2
    Default
    I'm beginning to think it's my imagination. Not every trip. But when I set it higher than probably most riders would so I have a nice firm pedal with little play type of feel, ride a couple times, it just feels lower(?). The adjustment nut looks like it was where it was when I raised it, but I didn't index it so it's hard to say.
    I have only readjusted it twice. It doesn't reset itself. It just seems lower than where it was. To me, lower feels spongier, but I have no reason to think there is air in the system, although that may be a possibility.
    '12 Raven/DS70/PC/Block offs/Cut air box short v-stacks/Timing adv/-1 frt sprocket/Metzeler M7RR's/90o stems/spools/sliders/GD opener/Acc-USB plugs/Volt meter/Jewel switch/Phone mount/LEDs: Amber Jewel/Headlight/Smoke tail & flush frt & pod sig-DLR/underseat red sig-brake/DMP fender eliminator/Lithium battery/Puig touring screen/Grip Puppies/Seat 1.5" higher/Rox 1" up & back risers/Gear Indicator/KTM tail pack/M1 alarm/CC/Tank Pads/SS BL/3 back surgeries/Old fart balls of steel/Happy to be here.
  4. #4
    Join Date
    Oct 2017
    High Point, NC
    Posts
    281
    Rep Power
    2
    Default
    Quote Originally Posted by MrFrzZ View Post
    Where do you live in SC... I'm in High Point NC.
    Regards Neighbor! Rob
  5. #5
    Join Date
    Mar 2016
    South Carolina
    Posts
    155
    Rep Power
    3
    Default
    The temp has been all over the place recently, but If you've found an air pocket, I'd imagine it would be a night and day difference rather than a slightly different feel. Do you have stainless lines or the OE rubber lines? If you havent made the switch to stainless yet, I highly recommend it. I put my front on about 3 weeks ago, and just did the rear this weekend. i went from pushing my foot down to more or less just depressing using more toe pressure and feeling a very positive feedback.
    Im in Spartanburg ,SC. Just rode up to Tryon this past weekend with the wife.
  6. #6
    Join Date
    Oct 2017
    High Point, NC
    Posts
    281
    Rep Power
    2
    Default
    I still have OEM rubber lines. Will go to SS eventually. That may be what I am feeling. Just did a radial master cylinder and SS lines on my son's 2000 SV650. OMG you wouldn't believe the gunk in his system.. Horrible.. He just bought the bike a few months ago. We were guessing the fluid had never been changed.
  7. #7
    Join Date
    Mar 2016
    South Carolina
    Posts
    155
    Rep Power
    3
    Default
    I think I'm going to try to swap in a brembo 17rcs mc onto me next since it's eventually going to be a track tool as long as this summer goes alright lol. In all honesty, for the money invested, I think Stainless lines are one of the most beneficial upgrades for this machine.
    New rear sets, racetech suspension, and brakes, and I think I'll be content with it until I'm using up all the available power. Then I may look into a r6 or something else. For now the fizzer has a lot to teach me.
  8. #8
    Insert title Here Scott_Thomas's Avatar
    Join Date
    Apr 2012
    Quakertown, PA.
    Posts
    4,874
    Rep Power
    22
    Default
    +1 I upgraded last year to stainless lines, new pads and changed fluid and it's night and day. Very little pressure needed, whereas before I was applying lots of pressure.
    Mods: /Shogun Sliders/ C. Werkes FE/ ZX6R Mirrors/ Flushmounts/ POW Tank Pad/ PC5/ Driven BO's/ Shorty Levers/ Kuryakyn Throttle Lock - Bar Ends/ AHR - HID/ LEDs-Air Scoop/ T-rex Spools/ Woodcraft Clip-Ons/ Kuryakyn ISO Grips/ Puig Racing Screen/ Ram Mount/ / Stompgrip/ Red Rim Stripes/ Red Spike Bolts/ CF Gas Cap Cover/Billet Alum. Pegs/ MD Integrated Taillight/ Healtech GiPro GI/Airbox Mod/ Short V Stacks/ FZ6 Cams/ Galfer Stainless Braided Brake Lines/ Volar Sintered HH pads/ Ogio tailbag
  9. #9
    Join Date
    Oct 2017
    High Point, NC
    Posts
    281
    Rep Power
    2
    Default
    Thanks guys
Similar Threads
  1. Replies: 5
    Last Post: 12-29-2017, 07:33 PM
  2. Shift lever adjustment
    By Rabbitman109 in forum FZ6R Mods
    Last Post: 06-22-2012, 01:12 PM
  3. Rear brake adjustment
    By nismos14 in forum Garage / Mechanical Help
    Last Post: 05-25-2012, 08:51 PM
  4. Rear Brake Light Switch Adjustment
    By 2QUIK4U in forum Garage / Mechanical Help
    Last Post: 04-22-2012, 02:51 PM
  5. Tell me how to raise the rear brake pedal/lever.
    By bobski in forum FZ6R How To's...
    Last Post: 05-01-2011, 05:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
