Thanks Thanks:  1
Likes Likes:  3
Dislikes Dislikes:  0
Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: Wiring fun: LED's, Alarm System, garage opener, flush mount gear indicator
  1. #11
    Senior Member sti491's Avatar
    Join Date
    Oct 2017
    High Point, NC
    Posts
    281
    Rep Power
    2
    Default
    5 month Alarm update. After living with this alarm for a while, and quieting it's incessant chirps EVERYTIME you shut of the bike, set the alarm... and on and on; the damn thing chirps all the time it seems (as it was designed, I just don't like that part of the design), I finally had enough. I pulled the siren out.
    I found I was running it in "silent" mode 98% of the time anyway, where only the lights flashing and ignition cut is activated. It's too bad in that mode it still audibly chirps for this, that and every other factory setting reasons (that as far as I know you can't change).
    So now, when I set the alarm I get a light flash. When I turn the bike off I get 3 light flashes and a key fob tune and buzz, reminding me to set it when leaving. If you mess with it, bump into it or try to start it with the key but without disarming, it either does short light flash or it flashes it's butt off while buzzing the key fob and playing it's quiet key fob song... and the fob tells me if it's a motion or other trigger setting it off.
    If you live in an apartment a "silent"alarm may not be what you need. For me I wanted the remote Key Fob warning more than anything else. I thought I could live with the chirps, but in the end could not... and neither could my riding buddies!
    '12 Raven/DS70/PC/Block offs/Cut air box short v-stacks/Timing adv/-1 frt sprocket/Metzeler M7RR's/90o stems/spools/sliders/GD opener/Acc-USB plugs/Volt meter/Jewel switch/Phone mount/LEDs: Amber Jewel/Headlight/Smoke tail & flush frt & pod sig-DLR/underseat red sig-brake/DMP fender eliminator/Lithium battery/Puig touring screen/Grip Puppies/Seat 1.5" higher/Rox 1" up & back risers/Gear Indicator/KTM tail pack/M1 alarm/CC/Tank Pads/SS BL/3 back surgeries/Old fart balls of steel/Happy to be here.
Similar Threads
  1. Need Help to Install Alarm system for my 2014 !!!
    By FZ6RThota in forum Garage / Mechanical Help
    Last Post: 04-07-2015, 12:03 AM
  2. Replies: 3
    Last Post: 05-29-2014, 12:48 PM
  3. Security / Alarm System Insurance Discounts
    By Rob in forum FZ6R General Discussion
    Last Post: 04-04-2013, 10:33 AM
  4. new exhaust or get alarm first??
    By lindz in forum FZ6R General Discussion
    Last Post: 07-12-2012, 08:15 AM
  5. what alarm system should i buy
    By springstime in forum Main Lobby / New Member Section
    Last Post: 07-11-2010, 05:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
