Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 4 of 4
Thread: Sprocket Mod Question
  1. #1
    Default Sprocket Mod Question
    Guys, I don't know enough about this and I read the sticky on the sprocket mod as well as a couple other FZ6 forums on it. Originally I was thinking -1/+2 or 15/48 set up because I rarely ride on the highway and want more low end power. BUT, I was reading that a -1/+0 or 15/46 set up is still a boost in acceleration and not as much hassle with higher RPMs. Any thoughts on that comparison set up? Should I go 15/46, or 15/48 for the most acceleration? Given most of my top speed ever is generally only going to be 60 mph.
    Thanks!
  2. #2
    Senior Member blkbrd's Avatar
    Join Date
    Apr 2011
    Midland, ON
    Posts
    352
    Rep Power
    8
    Default
    Check out this website...
    http://www.gearingcommander.com
    Sent from my SM-G903W using Tapatalk
    2010 Raven FZ6R -- Shogun No-Cut Frame Sliders -- CF Tank Pad -- ZX6 Mirrors -- High Beam Garage Door Opener -- Two Brother's Black Series C/F Exhaust -- Power Commander V -- Galfer SS Brake Lines -- EBC Sintered HH Pads -- Oxford Heated Grips
  3. #3
    World Most Bad A$$ 6R Marthy's Avatar
    Join Date
    Jun 2010
    Boynton Beach, FL
    Posts
    5,597
    Rep Power
    23
    Default
    It won't be a night and day difference in acceleration other than in first gear a bit on take off... What I would consider the most is if you're end up between 2 gears where you ride. Changing gearing will either help you (don't need to shift in the middle of a turn) or not help you on the opposite.
    BY example I went -1 in the front when I was doing track days on my FZ09. It wasn't noticeably any faster coming out the corner or faster/slower top speed but it did help me in some corners to be within the power band in 3rd gear. 2nd gear was too short and 3rd gear was just a bit too low in the rpms.
    So my suggestion is to take that in consideration...
    Martin
    Life is all about attitude. Be hard on yourself, easy on others.
    FZ6R sold...
  4. #4
    Default
    Good info. If I gained some pick up in 1st and was able to maintain stronger power band during cornering then that'd be great. I like to ride in higher RPMs anyway.
    Thanks for the tip as well blkbrd.
Similar Threads
  1. Sprocket help
    By JekyllandHyde26 in forum FZ6R Mods
    Last Post: 08-10-2014, 09:56 PM
  2. Front sprocket
    By Bozman in forum FZ6R Technical
    Last Post: 10-16-2013, 07:05 AM
  3. This sprocket?
    By Lefty in forum FZ6R Mods
    Last Post: 09-19-2011, 08:17 AM
  4. Question about +1/-3 sprocket
    By Serother in forum FZ6R Mods
    Last Post: 02-15-2011, 12:53 PM
  5. -1/+2 sprocket!!!!!!
    By Mikester88 in forum FZ6R Mods
    Last Post: 08-30-2010, 08:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
