Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
Thread: seat height question
  1. #21
    Junior Member
    Join Date
    Apr 2015
    Knoxville
    Posts
    16
    Blog Entries
    3
    Rep Power
    0
    Default
    Be careful when lowering I loosened I think it was four bolts slowly and it was supposed to go down slowly and it just went down fast
  2. #22
    Join Date
    Jul 2014
    Orchard Park, NY
    Posts
    77
    Rep Power
    5
    Default
    I suggest being careful using the preload adjustment to aid you in being able to flat foot, that's really not what it's for. There's quite a difference in handling between the lowest and highest settings.
    Also, as an inseam challenged 5'5" guy, checkout the Daytona M-Star GTX boots. They're pretty pricey, but fantastic! In addition to being just really good quality riding boots, they give me somewhere around an extra 2" of reach. They have a (I think) cork insole. From the outside they look totally normal. With my height and ~29" inseam I can flat foot my stock FZ6R wearing these. Also my rear preload is at 5 so not much sag. To me they were worth the expense. They can always be sent back to Germany to be re-soled/repaired should you need it.
    They also make me want to be like George Constanza with his Timberlands (seen that episode?) and never take them off They are a tad awkward to walk in with the thick insole but it's not bad at all.
    Check 'em out, Revzilla has them.
  3. #23
    Senior Member xorbe's Avatar
    Join Date
    Apr 2015
    Bay Area, CA
    Posts
    169
    Rep Power
    4
    Default
    Quote Originally Posted by BlastOffMike View Post
    The default is 3 and the softest is 1. The way I ride casually, it won't won't make a difference ... and checking the tire pressure from the way the seller gave it to me ate up anything I got from that. 19 psi ...
    Oh man, so I got on my old low Ninja 250 after riding the FZ6R for a week -- I've changed my mind, that's too low! Super easy, but it felt like a lawn chair, haha.
  4. #24
    Join Date
    Apr 2015
    Bay Area, CA
    Posts
    169
    Rep Power
    4
    Default
    I've never felt overly short (or tall) in 40 years, but looking in the mirror, seems like I perhaps have a taller chest and my lower legs are a bit short, just comparing against pics of other runners online. Approx inseam of 30-31". Another challenge probably is my large upper thigh muscles from speed running.
    Things have been ordered: 2" lowering link from eBay, Soupy's adjustable kickstand, 17/43 sprockets + Speedohealer, Corbin seat, Puig w/s.
  5. #25
    Join Date
    Apr 2015
    Bay Area, CA
    Posts
    169
    Rep Power
    4
    Default
    Quote Originally Posted by xorbe View Post
    (And front/rear stands.)
    Everything arrived, except Corbin is totally mia. I guess I'll have to call them to see if they misplaced my order or what.
  6. #26
    Junior Member
    Join Date
    Mar 2017
    Port Macquarie,NSW,Australia
    Posts
    3
    Rep Power
    0
    Default
    Hi there
    I know this post was a long time ago, but I struggled to touch the ground and I don't understand as the seat height is stated as 785mm which is the same as the Ninja 300. We have taken the seat adjuster out and now have lowered the suspension and the front forks. I am not quite 5'2 so you can see my problem. I have ridden an earlier model and it didn't seem as tall.
    I'm wondering if the problem is the width of the seat and I am going to look at having an upholsterer make the front of the seat narrower. Has anyone tried this?
  7. #27
    Join Date
    Jul 2014
    Orchard Park, NY
    Posts
    77
    Rep Power
    5
    Default
    That’s odd that an earlier model seemed okay to you. Other than (according to a rather astute member here) a slight change to the passenger grab handles, there haven’t been ANY real changes made to this bike since it was introduced. The width of the seat is certainly a factor. Are you sure it’s the factory seat on your bike and not something aftermarket? I’m just confused on how an earlier model could have seemed okay. I guess you’re confused about that too.
    I see you’ve done everything you can to lower it. Have you checked the preload on the rear shock? As I stated like 3 years ago (haha), it shouldn't be used to adjust height. But if you’re light and it’s set high, that could be a factor for you because the suspension won’t sag much or at all. Also you’ll have better handling on a low setting assuming you’re light.
    Best of luck making it work for you and welcome to the community!
  8. #28
    Member MadMaxx's Avatar
    Join Date
    Mar 2018
    In a van, somewhere in the SE United States
    Posts
    34
    Rep Power
    0
    Default
    I think it has as much to do with hip width as it does with inseam.
    I'm 5'7" and almost flat foot in the high setting, it's honestly more comfortable than how much of my lower abdomen is contacting the "corner" of the tank in the low position, so I use that.
  9. #29
    Junior Member
    Join Date
    Mar 2017
    Posts
    3
    Rep Power
    0
    Default
    Yes, I am definitely confused. I bought it brand new in 2017 as old stock so I assume it is the factory seat.
    I am fairly light (would like to be lighter of course) and the lowering doesn't seem to have affected the handling so I could leave it as it is! But, I do wonder if it has affected the safety in an emergency braking situation so would like to raise it back up if I could and that's why I am wondering about the seat width.
  10. #30
    Junior Member
    Join Date
    Mar 2017
    Posts
    3
    Rep Power
    0
    Default
    The problem for me is when I stop and I am on loose gravel or uneven ground, and as it quite heavy for me, I loose my confidence trying to park it and not drop it!
    Maybe I should spend some time at the gym and get stronger legs!!!
Similar Threads
  1. How to Adjust the Seat Height
    By Senaca in forum FZ6R How To's...
    Last Post: 05-10-2018, 02:13 PM
  2. Changed up handle bars and seat height
    By efforex in forum FZ6R Mods
    Last Post: 09-05-2012, 01:34 PM
  3. Height Adjustment
    By Nyuu in forum FZ6R Mods
    Last Post: 07-31-2012, 06:56 PM
  4. Seat height and handling
    By locwan in forum FZ6R General Discussion
    Last Post: 05-12-2011, 09:43 PM
  5. seat height change by shock compression
    By fz6r marc in forum FZ6R General Discussion
    Last Post: 08-16-2010, 03:37 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
