Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 9 of 9 FirstFirst ... 789
Results 81 to 90 of 90
Thread: Effects of changing sprockets
  1. #81
    Join Date
    Apr 2015
    Philly
    Posts
    106
    Rep Power
    4
    Default
    Quote Originally Posted by tho9504 View Post
    Is +1/+0 the same as +0/+1? Instead of changing the front sprocket, if i changed the rear with +1 with that lower the RPMs at cruising speed? The only reason i am asking is because if i am on the highway or something, i hate reving the hell out of my bike. and the rear seems like it would be easier to change than the front (dont have any experience, just a guess).
    Ok, so i went to check some sprokets on e-bay and this is the information i got from their website:
    For QUICK Acceleration 16/47t gear ratio (Quick off the line, snappy roll on's, easier wheelies), The +1t rear sprocket change is very mild change, in the direction of quickness, with no noticeable side effects other than very slightly higher freeway cruising rpm's.
    For FREEWAY RATIO 16/43t FASTER TOP SPEED, and LOWER HIGHWAY CRUISING RPM's - The -1t rear sprocket is a mild change, the -3t will be very noticeable in lower top gear cruising rpm's and higher top speed, but slower off the line..
    Original Factory Supplied OEM 16/46t size sprockets are the calculated "Happy Medium" of off the line acceleration, roll on's, and reasonable high speed engine rpm's with the least amount of compromise on either top end or low end acceleration
    Teeth and Sizes Explained...
    ** A -1t front sprocket change is EXACTLY the same ratio change as +3t rear sprocket change.
    ** A -2t front sprocket change is EXACTLY the same ratio change as +6t rear sprocket change (Very Extreme change)
    ** A -1t front and +2t rear combination is EXACTLY the same as a +5t rear only change with stock front sprocket.
    ** A larger rear sprocket number of teeth size requires a longer chain, however +1 or -1 tooth on the front sprocket only requires NO chain length change.
  2. #82
    World Most Bad A$$ 6R Marthy's Avatar
    Join Date
    Jun 2010
    Boynton Beach, FL
    Posts
    5,599
    Rep Power
    23
    Default
    +1 front or -3 back (F17T or R43T) is about the same ratio. Most of us went with 17T at the front... that's about -300RPM in the cruising range. Also make the speedo accurate.
    Martin
    Life is all about attitude. Be hard on yourself, easy on others.
    FZ6R sold...
  3. #83
    Senior Member xorbe's Avatar
    Join Date
    Apr 2015
    Bay Area, CA
    Posts
    169
    Rep Power
    4
    Default
    No, +1/0 would be similar to 0/-3. I am installing +1/0 soon (17T), then I have a 43T sprocket for additional 0/-3 later (giving +1/-3 total). Stock is 16/46. If you get extreme, you'll need to adjust chain link count, acquire speedohealer.
    Sorry, I did not notice new page 3 with replies already.
  4. #84
    Junior Member SebUK's Avatar
    Join Date
    Mar 2015
    Luton, UK
    Posts
    6
    Rep Power
    0
    Default
    I'm on 17/43 now and it is nice for what I need, as rpm are lower while on motorway. However I do feel lack of acceleration under 7kRPM. Also I found myself using 1st gear much often then before.
    This set up suits me, but if I would ride more in the city that would be unplesent ride..
  5. #85
    Join Date
    Apr 2015
    Bay Area, CA
    Posts
    169
    Rep Power
    4
    Default
    Quote Originally Posted by SebUK View Post
    Hey glad to hear someone else has 17/43 already. The math makes it look like a decent highway setup for cruising 72 mph @ 6100 rpms.
  6. #86
    Junior Member
    Join Date
    Mar 2012
    Washington DC
    Posts
    30
    Rep Power
    0
    Default
    I am gonna take the bike into the shop next week. Ive been reading the posts... will a stock chain fit the +1 up front change?
  7. #87
    Default
    Quote Originally Posted by leovito View Post
    Did it? Curious as well..
    If not, I think I'm gonna do the +1/0 for the speedo correction. What size chain should I get? Going to grab a red one while I'm at it.
    The greatest EDM artist you've never heard of..
    https://www.reverbnation.com/digitaldisciple
    _________________________________________
    2014 FZ6R Raven Edition
    MD Smoked Taillight | PUIG Dark Smoke Windshield | Flushmount Signals | Vortex Fender Eliminator | RED SMD5050 Accent LEDs | RED Shorty Levers | K&N Filter | ZX6R mirrors | ELFR-1 Flash Relay | Shogun Frame Sliders | Custom Dual Garage Openers | Power Commander V | Two Brothers Exhaust | Racetech Suspension
  8. #88
    Default
    getting a headache reading this thread... dont know what way to go, background if it counts, i have a two bro's exhaust, pcv with a marthys map, and the air box mod... ride alot of country roads, and love to leave the stop signs like im a drag racer lol, but also do alot of long rides (300-400 miles in a day), my current chain and sprockets are shot, so i picked up a new chain, and deciding what gearing to go with, vortex doesnt have any 46's, so 47 is the next choice (49 is the other one in stock on revzilla), so if i go with a 47, whats the best choice for the front? i dont want to kill the top speed to badly (im riding alot with people on 600 supersports, so i dont wanna be left too badly in the dust)
  9. #89
    Senior Member sti491's Avatar
    Join Date
    Oct 2017
    High Point, NC
    Posts
    281
    Rep Power
    2
    Default
    Quote Originally Posted by xorbe View Post
    I am about to put on a 15 tooth front sprocket for better pick-up. Today coincidently. Yesterday I checked my stock RPM/speed. I got 70 mph at 6,000 rpm. So is the only reason you are doing this a speedo accuracy? It's only off a couple MPH stock. Easy too correct in your head and not spend a dime... Just curious.
  10. #90
    Default
    nah, speedo would be more acturate going 17/46 from what ive understood, ill be getting a speedo healer anyways, mine reads 61mph at 55mph on gps
Similar Threads
  1. Changing sprockets?
    By Fizzi6ergal in forum Garage / Mechanical Help
    Last Post: 04-07-2013, 05:59 PM
  2. Changing Handlebar
    By danieljardim in forum FZ6R Technical
    Last Post: 08-20-2012, 08:35 AM
  3. Changing the clock
    By FZ6Rgurl in forum FZ6R Technical
    Last Post: 06-21-2012, 09:11 AM
  4. Changing the Oil and Filter
    By cam7777 in forum FZ6R Technical
    Last Post: 02-18-2012, 12:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
