Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Grip heater installation instructions
  1. #1
    Super Moderator JSP's Avatar
    Join Date
    Jul 2009
    Bend, OR
    Posts
    6,199
    Blog Entries
    18
    Rep Power
    25
    Default Grip heater installation instructions
    Here is an article I wrote up to walk you through installing grip heaters.
    http://voices.yahoo.com/how-install-...431.html?cat=5
    Thanks to those here who helped me through the process. I added a thanks and a plug to www.600cc.org at the very bottom of the page too. I hope I got everything right in the process of writing it all out.
    I wish they would let me add actual pictures throughout the process... even though i didn't take any, haha.
    -Jay
    You call it facial hair.. I call it AWESOMENESS escaping through my face!
    Previous Bikes: 09 Rebel 250, 09 FZ6R, 09 R6, 11 FZ8, 2002 Bandit 1200S
  2. #2
    Senior Member bleedinblue's Avatar
    Join Date
    Mar 2012
    Indiana
    Posts
    1,728
    Rep Power
    16
    Default
    Bump, seasons are starting to change.Thanks jsp, bookmarked until I have everything
  3. #3
    waiting out winter MNGreg's Avatar
    Join Date
    Jun 2011
    Maple Lake, MN
    Posts
    2,523
    Rep Power
    19
    Default
    Agreed! Thanks for the information from you and Nastybutler!!
    I ordered a pair of Symtec Grip heaters from Bikebandit. Should be here this weekend or early next week. I am geared up to wire in a relayed distribution terminal block also this weekend to prepare for this install. It has the metal toggle switch so I just need to check out homedepot etc for a weatherproof boot for the toggle switch.
    I purchased the block from Radio shack but the only one they had was pretty tiny (to fit the connectors on many of the wires (projector battery connection etc, etc). So I went to home depot and got a Tyco Electronics dual row terminal block. Instead of using a formed jumper I will just have to create my own jumpers via wire to each of the rows I want to be either + or -. Use little red or black loops of wire according the the +/- status of that connection. Not as nice as a formed jumper bar but cant find anything to fit.
    Current DB Windshield, Immortal Graphix Clear Tank Pad, TapeWorks Reflective Wheel Stripes, Lightning Performance Sliders, T-REX Spools, MotoCentric Sport Saddle, Givi V46, GTI-R HID Projector, Banshee Horn, Speigler Blue Brake lines, Rizoma Engine & Crank Case Guards.
    Desired Givi V35. Puig Touring Windscreen, TechSpec Tank Grips, Rizoma F/E, +1/0 Sprockets, New Clutch/Brake Levers.
  4. #4
    Join Date
    Mar 2012
    Indiana
    Posts
    1,728
    Rep Power
    16
    Default
    I found a set of grip heaters for $19.99, so I wanted to post the link in case anyone else is on a budget.Or to give you guys a couple of days to "school me" if they are a pos before I order them.
    Tusk Grip Heater Kit | ATV | Rocky Mountain ATV/MC
    Also, besides open bar ends.Whats the biggest difference between street/dirtbike grips?Are the sizes/length any different?Or can I just cut open the bar ends?Id just like something with more bite than most street grips when I get thicker gloves.
  5. #5
    Join Date
    Jun 2011
    Maple Lake, MN
    Posts
    2,523
    Rep Power
    19
    Default
    I saw those Tusk ones on amazon. Very good reviews. For the splice wire, I would just go buy a wx proof one instead of the one that comes with any of these kits, since you can't heat shrink over them.
    I went with the symtec (heat demon) because of good reviews and the company is in FRIDLEY MN (about 30-40 miles from my house) keepin it local.
    I cut back the heat shrink on my tail light and tapped into that to power my relay which is under the passenger seat. Then ran +/- wires wrapped in electrical tape under has tank to under dash to a small barrier strip. I would buy a radio shack euro block and cut down to size and just screw the wires into that when I tidy it up this winter, instead of the US barrier strip. Less bulky.
    Sent from my SCH-I500 using Tapatalk 2
  6. #6
    Super Moderator dart1963's Avatar
    Join Date
    Aug 2009
    Bluemont, Virginia
    Posts
    6,077
    Blog Entries
    2
    Rep Power
    24
    Default
    Quote Originally Posted by bleedinblue View Post
    1) Wire them with care, just from reading through the reviews. They wired them for ATV with thumb throttle, so the wires are delicate. Looks like securing them with a wrap of electrical tape fixes that. They also do not have a sticky back, so you'll probably want to get doublesided tape or something to make sure your throttle doesn't spin around them. At half or more the price of the symtec's though, great find!
    2) As long as they are 7/8". you can cut the ends. I had to do that on the cheap grips I put on, no biggy.
    _________________________________________
    Don | "Deer suck! Back on two's next year!"
  7. #7
    Monster Member JT's Avatar
    Join Date
    May 2012
    Bakersfield CA
    Posts
    7,681
    Rep Power
    25
    Default
    Thanks for the write up. it will surely help me in a month or so.
    FAB 5 President
    http://www.youtube.com/user/JT2012FZ6R
  8. #8
    Join Date
    Mar 2012
    Indiana
    Posts
    1,728
    Rep Power
    16
    Default
    Quote Originally Posted by dart1963 View Post
    I was thinking about doing a dry fitting before installation.Instead of taping the wires in place.I was thinking about poking a hole through the grips, and running the wires through the inside.Then maybe trim down the backside of a grip donut to keep the wires in place in a clean way.
    I read that about the warmers not having a sticky back.I was just going to use grip glue on them to.But the double sided tape will be quicker and insulate the warmer on the bare bar side.I'll probably just go that route.
  9. #9
    Join Date
    Jul 2009
    Bend, OR
    Posts
    6,199
    Blog Entries
    18
    Rep Power
    25
    Default
    Cold weather coming! Grip heaters make a world of a difference!
    Stay warm!
    -Jay
  10. #10
    Member mikebaileyvienna's Avatar
    Join Date
    Jul 2012
    Vienna VA
    Posts
    129
    Blog Entries
    18
    Rep Power
    7
    Default follow JSP
    did this last year with JSP's instructions. Great!
    Yana Shiki H.I.D. Kit (low beams only) // Pit Bull Rotary Steering Stabilizer // Chain and Cable Luber
    http://www.fz6r-forum.com/forum/blogs/mikebaileyvienna/
Similar Threads
  1. instructions for how to derestrict yamaha XJ6N-L FZ6R
    By luke1088 in forum FZ6R How To's...
    Last Post: 03-20-2018, 01:42 AM
  2. Instructions on how to Derestrict your FZ6R (10 Steps )
    By NightWolf in forum FZ6R Technical
    Last Post: 07-14-2014, 06:16 PM
  3. T-Rex Frame Slider Instructions
    By rahuljp in forum FZ6R General Discussion
    Last Post: 01-15-2014, 10:43 AM
  4. Yamaha Seat Cowl Installation Instructions
    By eNigma17 in forum FZ6R Mods
    Last Post: 01-11-2014, 11:49 AM
  5. Any Grip Install DIY instructions for the fz6r
    By ajcatx in forum FZ6R General Discussion
    Last Post: 04-14-2010, 10:23 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
